Need Help with flashing ROM PLEASE!!!
EVObastard
Active member
Jan 25, 2013
31
I wiped/factory reset then wiped cache then delvik cache then went to install zip from sdcard and I got a black screen with a open white box with a yellow arrow coming out and blue android standing next to it. Same thing happens when I try to restore.
EVO 4G with revolutionary
Update: The only option that worked was to power off and now it looks normal but I would like to know what that was and why it happened.
Gonna try again
Woohoo, got it to work. My first ROM yeah. :cool: I still would like to know what happened though.
Sounds like the ROM was being installed. That's the stock look for a ROM being installed, so I'm gonna assume you're using CWM?
Sent from my HTC Vivid CyanogenMod 10 using Android Central Forums
catladyjane
