Need Help With My First Android Device From An Experienced User
  • Start date Start date
A
AC Question
Hi everyone,
So I just ordered my first Android Device (BlackBerry Priv).
I red some things online about how to handle your first boot up. Like waiting around 20 minutes after the initial setup. I also red something about doing a factory reset after your first big update.
Do you guys have any tips or tricks to make sure my experience will go as smooth as possible and that my phone will be as fast as it possibly can?
Thanks in advance guys and have a great day!
Hi, regarding the second point about doing a factory reset, this is totally your choice. When I usually update my software I don't bother with a reset, but others do and swear it makes the phone better. It won't harm the phone to reset it.
I don't think you need to wait 20 minutes on first boot up to use the phone, I've never heard of that one before :P
Just make sure you charge the phone for a while before powering it up then get stuck in :) come back and let us know if you have any issues or questions.
i don't bother with the factory reset thing unless I have troubles. This phone has worked pretty smoothly since the first major update.
Chauncey the Gardener
