Need help with Network Camera on Droid browser
matrix2004
279
I bought 2 Panasonic BL-C111A Net cams. I setup everything but when i go to the camera access page on the Droid browser it shows the page but not the video feed. The page is blank where the feed should be. Everything else on the page is there. Any ideas?
I think they are saying the url should be <ip address>:<port>/mobile.
For example: 100.100.100.5:7000/Mobile or mycamera.net:7000/Mobile; substituting your IP address/URL & port #'s. You might also try /mobile and /Mobile since they contradict themselves.
I found this also.
You are using the camera’s local IP address when trying to access the camera from the Internet.
Use the global IP address assigned to you by your ISP and the port number of the camera when accessing from the Internet, or use the URL provided by the Dynamic DNS service provider, such as Viewnetcam.com. See Section 4 Configuring the Camera for Access from the Internet in the Operating Instructions for more information.
Did you ever find a solution to seeing live feed on DROID?
I just got a DROID X and cannot see my camera's live feed. I used to be able to on my iPhone. I can see the live feed on my PC so I know the set up is correct and the URL is correct. When I change the refresh rate to 3s, I can the camera feed but it is delayed 3 s. If you ave resolved this issue, please let me know so I do not need to return the DROID X and return to iPhone. Thanks.
ihariff
