need help
shanimal92
46
5
I use a mac, but i have windows 7 installed with bootcamp. i used bootcamp to do the rooting and unlocking process because i was a lazy bumhole and didnt look for a mac version. now i see root, unroot, and unlocking tuts everywhere :/ I have tried to flash the new radios (from rootzwiki) onto my device (i didnt need two since i use the .zip file earlier release) just to see if i could adb into my device, turns out i cant.
1. I went and downloaded the android sdk for mac
2. extracted the folder to my desktop
3. opend tools(?) and clicked on the "android" program
4. i checked install android 4.0 and 4.0.3; it did
now i had all these new folders in my android sdk folder
6. i moved the folder to my douments folder and renamed it "android sdk"
when i try and use adb to reboot my phone in to bootloader (got the command off of the post on droidforums) it says that my device cant be found. is it because i use windwows to root and unlock my device?
I don't have a Mac but I know that one doesn't have anything yo do with the other. It is a connection problem. You must be skipping something.
it just says in terminal "error: device not found" : /
OK I'm going to send you a pm with a email address of a friend of mine. Write him and hopefully he can help you out tomorrow.
Welcome hope he gets back to you quick. Good luck
Haris18
