Need help
Wicked96ta
57
Hey everyone, last night I tried rooting my phone using unrevoked and everything was working fine until I tried using Hydra's kernel. Now my phone is stuck in a boot loop. It will just show the HTC green and white screen and then it goes to the verizon screen and then starts again with the HTC screen. Please help me fix this.
Its OK to pull the battery on a kernel boot loop.. read hydras site... my phone had boot loop with all the hydras.. try the kingxclicks
Get the king #1 BFS kernel. Boot into recovery mount sd storage. Once it pops up copy it over to your SD card. Unmount sd storage. Flash the kernel, be happy.
How do I do the the nandroid restore? Been at this all day
the first question would be did you do a nandroid back up...if you did then hboot(power vol down)->recovery->nandroid->restore->you should have a list of dates to choose from, pick the newest
Ummm say I didnt make a back up, am I screwed?
Yes i did look in there and there is nothing. I am running the stock rom. All I did was use unrevoked to root and tried installing a kernel from hydra and that's when the boot loop started.
Now it keeps getting stuck on the HTC Incredible screen, the first one.
BTW, I really do appreciate you taking time to help me.
What do you mean "keeps"? It gets stuck and you turn it off or pull the battery?
Good news is you are not bricked, bad news is I am not quite sure where to go from here. give me a few minutes
You are very welcome, I am helping you as others helped me...but PLEASE please READ READ READ you will save yourself alot of stress
last resort is always to undo root...not sure what you will lose since you did not use nandroid or titanium back up but your phone will work,
scroll to the bottom of this like and FOLLOW instructions to undo root...then follow his instructions (they are very good for beginners) to root again or anything else you want to do
Howto: Root the HTC Droid Incredible - Technology - Jonamerica.com
you are probably getting boot loop B/C you are putting a froyo kernel on an eclair rom w/ a stock 1.xx radio
I know, I'm trying other forums to see if there is anyone who had the same issue as me. What I do is that if I get stuck in a boot loop or a freeze I have to do a battery pull. I am using my brother's Eris to put the zip files on my SD card because because my phone will not connect, and then once I'm done copying and pasting the zip, I put the SD card back in my phone. Then I hold down Vol down and power key. Everything was fine when I rooted with unrevoked, it was until I tried installing the Hydra kernel that everything went haywire. I never installed a custom rom or anything like that.
marksains61
