Need help!
Air Flow
4
Hello,I'm Air Flow and i have a problem with Google Play Store application,so... It happened like 2 weeks ago,i still don't know how to repair it,but maybe you guys know.
My Google Play Store application doesn't open anymore,it's not working in anyway and it happened for no reason.. when i try to open it opens for a millisecond and closes instantly.. i downloaded the newest version of Google Play,but it does the same,then i uninstalled all updates,cleared the cache,well just emptied,but it just doesn't open.... i searched for a lots of things on the internet,but i couldn't find anything that helped me repair the Google Play Store... I'm desperate to repair it,because i can't download any normal applications/games/videos or any kind of stuff,so i'm asking for 'your' help..
Regards,
Air Flow.
P.S. Sorry for my English
Try resetting apps. (Settings, Apps, tap the three dots, Reset Preferences.)
If that doesn't work try resetting date and time.
Sent from my Nexus 5 using Tapatalk 2
- - - Updated - - -
ok thanks,ill try
EDIT: Thank you,it works :)
GabrielGallegosPalacios
