need help
  • Start date Start date
A
AC Question
i was updating some apps on my s5 , and in the process i turned off my wifi by mistake , now it doesn't connect to the internet (it shows its connected but there is no signal ) what should i do ?
If this is with WiFi, clear the cache in the play store to see if it will download apps then.
Reboot the phone to reset everything.
If that doesn't fix it, go into the settings>Wireless & networks>WiFi and select your own network. Chose "forget" so you can disconnect and set it up again.
See if that will give the phone internet access once more.
leehrenterprises
