Need Quick Help!
AhmedDam
5
Yo peeps! SO i was looking forward to buy this Samsung Gear... but i was worried whether it would work with the Htc one....(4.3) Is there any alternative which might work on the 4.3 Rather Than the 4.1.2 Custom Rom?? :)
The Galaxy Gear works only with Samsung phones (GS3/4, Note 2/3)
It will not work with your One regardless of the Android version :\
Thankz for the quick reply... So you say there's no chance at all? A member from XDA, He could pair his gear on the htc one ( Running on 4.1.2 rom)... okay anyways, Maybe i would look for a sony smartwatch 2..
Maybe with a custom ROM but I'm 100% sure you can't do it on the stock ROM and I haven't seen any 4.3 ROMs that might support it. I'd ask said member how he did it...
Jayarealways
