need rom decision help!
taylorz_412
1,060
26
which rom is better for battery synergy rom or beans cusom stock rom?
i am leaning toward beans because it seems more like my kinda rom but need to know if battery is good or bad
Don't be afraid to try both. Simply nandroid and jump to something new. You can always return to your favorite as long as you backup beforehand.
Sent from my rooted/stock Samsung Galaxy SIII using Android Central Forums
I am gonna try beans, But step one says make sure you have Kexec recovery installed. What is that exactly?
Thanks!
Sent from my SCH-I535 using Tapatalk 2
Beans new build 5 + jelly bomb.7.2 = best rom ever. So smooth and works fkawless
Scratch build 5 make it 6 lol
Tapatalk'd / Rooted Galaxy S3
I messed with Synergy for a while. It's ok. Not super amazing IMHO and could use some cleaning up (vibrates whole off and charging, can lose 4G reconnection after toggling between that and 3G). I imagine it will be awesome soon, but at the moment it's just ok.
I'm considering trying Bean's but the thread seems to have as many complaints (if not more) than the Synergy thread.
I'm assuming this - [Recovery][Kexec] Recovery with Kexec support - How to repack boot/recovery images - xda-developers
Is this recovery necessary if we already have cwm installed? Is this for flashing kernels and a way to bypass the locked bootloader? Can we just wipe data/cache then install the file in cmw via the recovery or does these roms require tweaks to the kernel?
Whoa aokp available for s3 now? Is this via the kexec workaround?
Yes. Follow the process, but it is not fully functioning yet.
Sent from my SCH-I535 using Android Central Forums
ruhidubey0188
