Need some advice/help on i337 AT&T Galaxy S4
Mithan Kitara
11
Hi guys, I am having some issues with my Girlfriends S4 (i337 AT&T Version).
The issues I am having are below, but I want to know if you guys would recomend me upgrading it from 4.2.2 to some other ROM that may clear out these issues and what you would suggest me to upgrade it to?
I want something that is STABLE, fairly close to the stock S4 Build or even the Stock Android GUI and easy to upgrade too.
Or is the phone just screwed and I should look into replacing it? I have not upgraded the phone from 4.2.2 because as I understand it, doing that locks the bootloader and makes it a pain in the *** to root and upgrade.
Issues she has:
-When recording video, sometimes it wont record voice, sometimes it does. No idea why this is doing this.
-Sometimes video's refuse to play, then it starts working again.
-SD Card appears to disengage at times. Its Lexmar, maybe I need to get a Patriot like mine.
-The phone just intermittantly disengages from the Cell Network or Wi-Fi network. She sees it mostly when she uses Viber. It runs well, then it just up and loses its connection then starts working well again
-Has had a few issues where people dialing her just cant get to her, its as if the phone has been turned off, or she cant dial out on the network.
-In certain cases repowering it corrects the issues for a while so I tell her to repower the phone once or twice a week.
This is what her phone is running:
SAMSUNG-SGH-I337
4.2.2
I337UCUAMDB
JDQ39.I337UCUAMDB
If this is not the correct place to ask these questions, please direct me to a better place, but I have found this forum to be an amazing resource with knowledgable people and I am not sure where to go :(
Re: Need some advice/help on i337 ATT S4
HE'LL NO DO NOT FREAKING UPGRADE
Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
I will buy it from you and send you a fully wiped kit kat official gs4 (as long as it's not cracked messed up screen scratched) with 4.2.2 I can root the heck out of it with 4.3 and up the boot loader can't be unlocked
Dude run a cyanogen mod and get the custom recovery with the lokidoki patch :) and honestly please get a 32 gig SanDisk never had a SanDisk card burn out it seems like she has corrupted data on the SD card back up your files on your PC and wipe the card
amaka
