Need some help PLS!!
glowworm3980
4
Good day, I have a 3G Xoom that I'm currently only using wifi on that's running 3.1. Didn't get 3G acticared cause I'm about to go to a area that I can't use 3G but wanted to use when I get back. I'm interested in rooting to get the SD card working so I can put more stuff on there. I have went through the forum and read them but it sounds like jiberish with putting .su here and this there. I know, I'm probally slow compared to some on here. So is there a simple guide and/or a video that will walk you through the process? Thanks again.
Glow
Thanks alot NewAge, will take a look at this tonight and see what I can do. I figured there would be a video out there since there's so many on jail breaking Iphones, that our droid geniusous out there would have one showing some love. All good, we'll see how it turns out. Thanks again! Oh, you know the time frame this takes from start to finish?
It all depends on how long it takes you to install the sdk. Once everything is set up its pretty easy. Takes a minute to unlock and wipe, seconds to push the files and you're done. The sdk took me a day to install properly. I kept getting errors and it was because not everything was installed properly. I has to delete the sdk several times.
kiki2025
