Need some help with mmmarks
From what I understand, ROMTools doesn't play nice with this phone. I used Terminal emulator to flash the custom recovery and RebornROM and that worked alright. PITA, but didn't want to wait until I got home from work. lol
so how do you use terminal emulator?
DL from the Market and use just like the command prompt on your computer. When you open it, it will pop up with a $... hit su and it will turn to a #, at which point you start inputting your commands. I suggest you type very carefully or turn off Swype to avoid errors.
Use this thread and download the files, move them to the root of your SD card via Astro or another file explorer , open terminal emulator and type the commands line by line. :)
mrrice360274
