Need some help with my maxx
06evo560hp
I need some help with my maxx it might be a dumb ? but i cant figure it out . Before the update came out i had the stock wallpaper and i added a picture to it both the wallpaper and picture showed up on my home screen, is there any way i can get that back with the update? Thanks for your help
So it sounds like you modified the wallpaper picture? Stock wallpapers are found in the wallpapers settings, but if you modified it, then it's probably in your gallery. Search through the gallery and see if you find it there.
Infinite358
