need some help with rooting
evoldroid
331
12
Can someone provide a link to where I can get the android sdk to install on my computer.please be patient guys this is my first time doing it.And the link that shows how to do it is like a Chinese map to me I'm lost.But I refuse to give up until my nexus s 4g is rooted.
I'm having similar problems. I think I'm fairly computer literate but I have not been able to root my nexus, even though its the "easiest" one to root.
Alot of times I assn following a tutorial and the links don't work.
I even had problems running the one click root method
Can't someone put together a tutorial that is easy to follow and has active links?
Sent from my Nexus S 4G using Tapatalk
There should be something that has all the links and instructions for people like us lol.I will get it tomorrow I won't let it win lol
you dont need teh sdk, use the one click.. there is even a video on how to use it ;)
it has drivers for you in there incase you cant find any.. the only thing you need to worry about is if you have windows 32 bit or windows 64 bit...
I did try it, I had a problem. Posted it in the main thread for the one click root
sfvsfvbf
