Need some help
CydKnee
4
Hello Everyone,.. I have recently purchased a Visual Land Connect tablet:
Model No. 97FC
Android Version:2.3.4
Baseband version: 2.04
Kernel Version2.6.36_android ine_qgb@InetSoftware #10
I like the tablet a lot, but I want to put honeycomb on it. It comes rooted out of the box so I have root access, and superuser installed. I need some help on finding the right Rom for it and flashing it. I have Rom manager installed but it says that I don"t have clockwork mod recovery installed. I have downloaded the recovery mod (came as a zip) but I"m not sure how to get it on the device correctly.
Any help or advice is greatly appreciated.
Thanks for your time :-)
Cydknee
Don't feel bad (it is not intentionally) - sometimes members and staff are a little preoccupied. :)
Hello and welcome aboard. Here's a link that I believe you'll be interesting in reading. http://forums.androidcentral.com/general-help-how/31622-getting-started-android-tips-tricks.html. Also, you will want to checkout your device's area of support - where other users of the same device love to hang-out. I hope you find this place insightful and informative.
Thanks for joining Android Central. :)
Thanks for the reply,... but I was hoping for a little more than the standard copy and paste reply,... and I have checked those areas,.. my device is not in your list,.. hence my request for help,.. but thanks I do feel better now,.... and enlightened.
Model No. 97FC
Cydknee
Sent from my zt180 using Tapatalk
Hello and welcome to the forums and to the land of Android.
I, myself have never even heard of that tablet. Where did you purchase it?
for all you outhere, the visual land is the same machine as the chinese MOMO9. there is all kind of info for that tablet. I already convert mine to ICS 4.0.1 and is working perfect.
Sent from my 97FC using Tapatalk
Fry's has one for $129. Been wavering on buying it - I already have a Nook - but it appears the Connect has HDMI output plus mic and webcam. Not that I really anticipate using them but the Nook has none of those.
Will let you know if I get it. Then maybe alesyl will tell us where we can find ROM to convert to the MOMO9. I didn't find it here on the site, but I'm sure the greater Web has soemthing somewhere, but I'd rather go with what has worked.
--Chez
There is a place you can find all info for update your tablet. flashmyandroid.cxx use the ployer momo9 to update as is the same machine copied and impruved by the chineses
Sent from my HTC MyTouch 4G using Tapatalk
Sent from my Glacier using Tapatalk
Subway_Surfers_Mod_APK
