need some info
hipespipes
15
So i just got the evo had the first droid and it got ripped of friday at the gym so decided to change to the evo i've rooted my droid and just did the evo just not sure if i have 4g we don't really have it here in modesto C.A yet but we get it in two mouths so right now its hit or miss. So what i need help on is the ip address i don't seen to have one at all it scans then says contacting to sprint but never does it just keeps switching back and forth.
Periods, commas and question marks; they are your friends.
Sent from my HTC Evo using Tapatalk + Swype
If you have 4g, it'll connect. If you don't, it won't. If it just scans and never finds anything, it's probably because there's no signal in your area. You should leave it off if you're not in a 4g area.
there were some people that messed up their 4G when they rooted with the second unrevoked patch - it was not the unrevoked group's fault... they were using the same radio patch that others were using as If you were one of those people, then you could have messed up the radio. There is a fix for it now, though!
sukarisw15
