Netflix NOT compatible with my device ( Nexus 6P) ?????
Addie_Goodvibes
429
61
Ok so My Nexus 6P arrived today. :)
I am going through the set up and installing apps and some of my apps say they are not compatible with my device??
Worse is the fact that NETFLIXis NOT compatible with my device..
This is a hge deal breaker for me...
Anyone else get this when trying to download their apps.?
Definitely strange. I've been using Netflix for about 2 weeks now on the 6P with zero issues. Maybe try uninstalling AND removing it from your "my apps", and then reinstalling.
I would clear your play store cache -- I downloaded and used it on day one.
Netflix works fine on mine. I can watch on the device and no issues casting. I'd echo uninstalling it, maybe rebooting your phone, then installing it directly from the Play App on the phone.
Thanks all for the replies, yeah i had to uninstall & reinstall , also had an android update so possibly the update to android also did the trick..
RohitPatidar57
