Never experience a slow phone & battery problem with all new 2-in-1 battery saver & RAM booster App
Sep 16, 2016
11
https://play.google.com/store/apps/details?id=com.mobiman.batterybooster
Booster, RAM and Clean master is one of the best battery saver and speed booster apps. Based on a new engine, with totally sleek design and new code, the app will surely be suited as one of the best new clean master, cleaner and performance boost apps in 2016.
Cleaner FUNCTION
With few simple taps you’ll be able to clean your phone from all the junk that is making it lag. In that way you will save more storage memory that you can use for any other purpose. Simply visit the junk cleaner section and delete all unneeded files.
BATTERY saver
In the battery saver section, you’ll be able to preset your phone and save battery when there are battery problems. For example you can set your phone to automatically lower brightness or turn off Bluetooth when it comes to a certain low battery level.
Quick Phone BOOST
With a simple tap, Booster, RAM and Battery Saver will enable you fast PERFORMANCE BOOST that will get rid from all the apps that are making your phone lag.
Memory BOOSTER
In the memory booster section you’ll be able to see which apps are running and how much each of those apps is spending from your RAM memory. Simply terminate the ones that drain it and boost the speed and performance of the phone.
Manage all APPS
Within the app you’ll be able to see all apps in a comprehensive list. When you see that some app is wasting too much battery or RAM memory, you can easily uninstall it with a simple tap. Additionally, see how much memory app is spending and delete it to save storage space.
Visually APPEALING and INTUITIVE
We worked really hard to make it intuitive and visually appealing. You’ll enjoy every second managing your memory and apps.
Booster, RAM and Battery Saver FEATURES:
- Cleaner function, clean all junk
- Performance boost with quick boost (1 tap)
- Battery saver (automatically turn off functions that are draining battery)
- RAM manager (close all the apps that are wasting RAM)
- Apps manager (uninstall any app)
Re: Never experience a slow phone & battery problem with all new 2-in-1 battery saver & RAM booster
Cleaner FUNCTION
BATTERY saver
Quick Phone BOOST
Memory BOOSTER
Manage all APPS
Thanks for sharing!
Thanks for sharing!
joelkmason
