Hi guys,
As everyone knows, the battery life on Nexus 4 is not good. So far, I've managed to get some decent battery life by turning off the 3G radio and using it only when needed. For example, when I'm at work or at home, I'm gonna be using Wi-Fi anyway, so I disable the 3G radio.
Whenever I turn on 3G, the battery drains like crazy (even with the display, wifi off). I turn down the display brighness as low as possible. Typically the phone only lasts 5 or 6 hours with minimal Screen-ON-time when 3G is enabled (like 30 to 60 minutes). I've tried disabling Sync but it doesn't seem to have any effect on the battery life. I usually have bad 3G signal near home but I've tried this experiment at work and other places where there is 5 bars of HSPA+ and it still doesn't help. When I switch to 2G, then it stops draining the battery. Any idea if this is normal or I have a bad 3G radio ?
