Nexus 4 Data Connection Problem
CurveDock
12
I've bought a Nexus 4 just a couple of days ago. I shifted from my old HTC Desire and used the same SIM card except this time the guy from the store where I bought it cut the SIM card so it's compatible for use on the Nexus 4 (Micro-sim). I already have a one month data plan on that SIM,but after I inserted it on the Nexus 4 it stopped working. I tried contacting my carrier and they say the data is still on. Is the problem on my phone? or my Sim Card?
Anyone experiencing something like this?
Every answer will be appreciated
The first thing I would check is that your APN settings have been loaded correctly - the only problems I have had with data connection on any phone I?ve previously owned has been down to these settings.
If these are correct, then would you perhaps have a friend on the same network with a micro SIM which you could pop in to your phone? If you get a data connection then the problem is with your SIM so simply get a new one, if not then re-look at the settings otherwise your phone may be the culprit.
Johnny83
