Nexus 4 does not turn on
batric
5
Hello,
I got my new Google Nexus 4 today and it does not turn on for the first time.
After pressing the power button, the system does not boot.
I?m immediately getting message ?Power off ? Shutting down? and it?s shutting down in a couple of seconds.
Tried:
- Rebooting the system by pressing simultaneously volume down + power buttons
- Reset to factory settings
Also, battery has been charged for almost 10 hours, but without any success. It?s still at ~50%.
Would like to know is this a hardware failure or software issue.
Thanks.
If your phone doesn't turn on, how do you know the battery is at 50% or less
While it's shutting down, you can see for a couple seconds battery status and keyboard for unlocking sim in the background.
Hold the power button until you feel a vibrate and then dont touch anything.. see what happens
You could try holding down the power button for a minimum of 30 seconds while unplugged, then plug it in, then hold the power button for a few seconds (until it vibrates), then release the power button and see what happens.
Neither option worked. It keeps shutting down.
I'll just return the device - this is probably something hardware-related.
Chauncey the Gardener
