Nexus 4 Frequent Graphical Glitch
Jade Edwards
Hi,
I've been the proud owner of a Nexus 4 for 3 weeks. I've had what I would describe a "graphic/screen bug" since I 1st powered it up, at 1st I just wondered if it would be a rare oddity and would go away, but if anything it seems to have gotten worse, it usually seems to happen if I'm using the stock keyboard. It happens in all apps even if I'm just using search or twitter or whatever. Here's a screenshot:
nexus 4 Glitch | Flickr - Photo Sharing!
I can't find anything relating to it on the net, even with all the other bugs and glitches that people seem to have found with 4.2.2
Does anyone have any ideas? Thanks in advance :)
edit: Sometimes the graphic glitch appears at the bottom of the screen, sometimes it's a grey square, sometimes it's white, but most often it looks like the link above.
You tried a factory reset? If not you should just get an RMA if you suspect it is just the device and no other apps causing it.
oztech123
