Nexus 4 Keyboard Sound
Soban Arshad
12
I want to change the keyboard sound in the stock keyboard when you press a letter. I want to change it to the Samsung keyboard sound. Does anyone know how to do this? P.S I'm not rooted
Since it is a system file, you would need to be rooted. Basically you take the Samsung file and rename it as the N4 file, then replace it in the system folder. You probably would want to make sure they are the same format. Otherwise, I'm not sure it would work. It is highly unlikely you will find a way without root.
Sent from my Nexus 4 using Tapatalk 4
noroldie
