Nexus 4 WiFi issue
festinator
225
So this just started today. My WiFi will show that it is connected, but the internet won't work. Turning WiFi off then back on works for a while but the problem always comes back. Hard resets have the same effect as turning WiFi off then back on. Any suggestions?
Sent from my Nexus 4 using AC Forums mobile app
Try turning off your router and turning it back on after a couple seconds. That may fix it.
If not, you'll have to see if the problem is with your phone or your router. Try connecting to a different router. If it works fine, it means there's something wrong with your router or router settings.
Turning it off and on fixed it. Thanks a lot!
Mine is having the same issue and I've repeatedly reset my router which fixes the problem for a short time. It eventually does it again the next time I'm trying to use home wifi. it's not my router because my Nexus 5 and my PC continues to function through the router. this recently started happening when the nexus 4 got the kitkat update.:mad:
guyuynhfrd
