nexus 5 battery case?
ianhanson85
271
So like most I have grown quite frustrated with the battery life of my nexus 5. Has anyone used a battery case? If so, which brand and how well did it work? Also, how much do they cost?
I see a generic one on eBay for 20 bucks that looks alright.
I'm just wondering what others have used.
Thanks
I have had this same issue with my Nexus 5 and I did an extensive search on Amazon and found the i-Blason rechargeable case, looked at reviews on the product and found they were all positive so I decided to try it out I've have the case for about two weeks now and I it works amazing and did a charge test with it with my battery at 20% and within two hours my battery was at 65-70% charged but I have found if you charge it and continue to use your Nexus 5 heavily then it will not charge as fast but overall well worth the money I purchased the case for 65$ but there are others out there much cheaper that I haven't tried yet so good luck to you
soraplzzzzz
