Nexus 5 Offline Music Help
  • Start date Start date
A
AC Question
SO, i just purchased a nexus 5 and its on its way atm, but i do listen to music alot, and i download from simplemp3downloader. (3rd party app) and on my old android (which had an SD card) all my music went to Google play music and i could access that downloaded music off-wifi/ data access. Will this be the same with the nexus 5 that has no sd card slot?
If it's on your internal storage, you can access the music whenever. If it's music you bought or downloaded from Play, you'll have to pin it to the device.
Sent from my Galaxy S4 running SlimKat 4.4.4
dayssss2
