nexus 6 power buttons HELP !!!!!!!!!!!
Oct 17, 2014
11
Guys i have a problem with my nexus 6
I tried to capture a pix under a water but as soon as my phone was wet it freeze and then it went in loop restart for an hour
Now it run normally after i dried it but power button doesn't work
it keep restarting on its own and after optimizing the apps it work normally :( life without my nexus 6 is very cruel :-X
Well nice try. First turn off and let it dry. But sounds like it is little bit late. Solution: need repair.
Sent from my Nexus 6 using Tapatalk
I've heard that putting it in a drum drying rice is done well then try to see what happens
Mod Note - Some posts have been cleaned. Please remember follow P.U.P.P.A.H. If you do not care for a post please use the report button or move along.
Thanks!
updating .. the power button has been replaced and i should mention that our device may survive a water splash but it won't go underwater :(
wanna thank some ppl for guiding me and not judging :)
Where did u change the power button?
Ariwenni15
