Nexus 6 Soft Brick Plz Help Me!!!
03tmobile
4
i use cmd " fastboot -w " and my phone stuck on LOGO.
Motorola: XT1103 - 32 GB
Baseband D4.0-9625-02.95
Bootloader : Locked
Can't use recovery or BP Tools or QCom...
Only driver Fastboot on PC .
i try flash recovery and Nexus ToolKit but not success ( Locked Bootloader )
Plz help me!!!
Bootloader : Locked
Plz help me!!!
Use the WUG Tool kit to fix it, use the Flash Stock + Unroot button tick the Soft Brick / Bootloop option as well.
Nexus Root Toolkit v2.0.5 | WugFresh
To do any type of flashing, you really have to unlock the bootloader first and foremost.... you won't be able to do anything until you get that done. The command is simple... fastboot oem unlock
This will wipe your phone, but once done, you'll be able to flash an image back on the phone.
Bootloader : Locked
This line alone may say that you are SOL. May have to return the phone.
I am having the exact same problem, cannot do anything because of locked bootloader! please help. Do not want an expensive paperweight!
This may not work, but the Nexus 6 is a Moto phone, so it's worth a try.
Motorola phones can be reflashed using RSD Lite--Moto's official flashing utility.
I would try to download the latest Nexus firmware from Google's website. Then Google "RSD Lite 2015 Motorola" and you should find the latest version.
I'll try to find appropriate links when I have time, but I've used RSD Lite to reflash a bricked Moto X 2013, Droid X and Moto Xoom. Good Luck.
honey12321
