L lawful12 Active member Nov 5, 2010 42 0 0 Nov 30, 2015 #1 Anyone know when the Nexus 7 2013 LTE version will be updated Marshmallow? Posted via the Android Central App
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,490 10,844 113 Dec 1, 2015 #2 Which carrier is it on? You can find the factory images here: https://developers.google.com/android/nexus/images?hl=en. You can install them manually following these steps: How to manually update your Nexus | Android Central
L lawful12 Active member Nov 5, 2010 42 0 0 Dec 2, 2015 #3 It is unlocked and not on any carrier at the moment.
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,490 10,844 113 Dec 2, 2015 #4 You should still be able to use the razorg firmware, under Nexus 7 [2013] (Mobile).
