nexus 7 battery ..
cedz
7
How do I know if my battery works normal? I'm browsing internet for about 15 mins ( moderate browsing, no watching of videos) and my battery is decreased by 7% (!) . please help . I need suggestions guys .. Please :(
Been having some battery issues of my own...
http://www.imgur.com/Rtgx6.png
Ignore the first half, as that isn't part of the problem.
Using the provided charger and USB cord, but have a USB extension cord so that I can charge it while sitting a few feet away from the outlet while still using it. Not sure if it is the battery or the wall charger.
Sent from my brand new Nexus 7 using Tapatalk HD
Lose the extension cord !!
For best charging speed, use the original adapter and cable only unless you KNOW that the replacements function properly. Turn OFF the N7.
For next best charging speed, make sure that the WiFi and Bluetooth are set to turn off when sleep mode is engaged -- settings > WiFi > 3 dots at top right (menu) > Advanced > Keep WiFi on during sleep NOT checked etc same for BT
Links to Known Good and inexpensive USB to microUSB cables have been posted - search and you will find them.
