My Nexus 7 went crazy last week. Worked perfectly then suddenly it wouldn't switch on. Connected to charger and got static screen with white pixels.
Saw that this could be due to extermely low batter so charged unit using original charger and cable. Eventually I was able to get it to do something.
I hit the power button and Google appeared. I then waited for the animation for KitKat to start... ... ... ... ... waited some more ... ... ... essentially I can wait until the battery is dead again and it will have just stayed on Google the whole time.
So entered Fastboot to do a hard reset. Sometime the Fastboot screen freezes and volume controls do nothing. Other times I can go through the various options, but if I select Recovery Mode I just get the Google screen again.
I have held a variety of buttons for minutes at a time with no effect. Searched extensively and I don't think there is anything I can do. Problem is I won this thing and I cannot get a warranty repair.
Can someone PLEASE give me an alternative to buying a whole new unit? I have had the back off and disconnected and reconnected the battery to no avail. Any advice or response would be gratefully appreciated.
Is there some secret ninja reset that needs the cover removed? I am willing to try almost anything.
Cheers!!!
Cheers!!!
