Nexus 7 problem with chardging and booting. Need help!
Svetislav Telecki
Firs of all wish to say hello to all.
Now,
I have some issue with my nexus 7
problem is that i can't it power up and when it is powered off when i connect charger nexus wont chardge battery.
nexus was connected on power supply with 45% battery status
next i put gadget for wifi, gps, sync, light. Small 4x1 gadget all android have it
i was turn off gps, sync and when i was tap on light button my nexus goes blank black screen doing nothing.
I was try to power off it and power on
when i power on device, it draws Google logo brighter then fade it for a few seconds then goes blank, and
after 10-15 second nexus displays X logo for 1 second and turn it off instantly.
after that point i havent anything on my display, even when i wait for 10 minutes, 30 min, ... 2 hours
in that state i try to press power buton and randomly tapping fingers on screen, when that is doing nexus
make sounds of clicking something but nothing on screen.
Next i search forums and find how to enter boot menu, I did it and try all options i have (power off, recovery mode, restart bootloader and start)
In recovery mode I try to press power and Vol+ button to enter menu to reset device, but when i do that i got this on screen:
Screen shows me green logo of bootloader faded then it goes black for 1 second, i bearly see what wrote under logo (no command or something like that)
So, i cant enter recovery menu at all.
Next i do was that i download SDK for nexus 7 and install usb driver on my pc.
I manage to flash all images on device and put factory ones in device but,
also i manage somhow to unlock my bootloader to be able to do this above.
So, I have bootloader and 4.2.2 version system image installed on device right now,
it is pure blank install, like that device goes from factory, but
I still have same issue with device, it won't turn it on, and it always go blank screen after showing X logo when powering on.
Also, i try several images to put on device and also, i try milion of times to enter boot menu and trying to recover but in vane
I was try also to remove back mask and reconnect battery for 1 minute, it always do same thing and won't power on.
I'm uploadin attachment in .rar format if someone wish to help me solve the problem or I just have only solution to return it in
store where i bought it. Attachment file contains 2 video files in .3gp format i recorded by my cellular phone and havent contain
any malicious software or something.
I ask for any help, any suggestion, any tip, or anything that i try to fix this
Thx to all!
MizzBizzzzz
