Nexus 7 Refusing to Install Flash player...HELP!!
leahinfl
I've tried several Flash downloads from several different sources. When I try to install it, I get an error message that says "App not installed." I do not know what else to do. Why won't it install the app? I have already checked the box to allow apps from unknown sources. Thank you in advance! This is the only reason I bought a tablet. If this doesn't work for me, it's useless.
I'm sure someone will chime in with better knowledge - but here is what I know (or what I think i know) -- If your N7 is stock then flash will not install all alone. Basically is it not supported. You can however download a browser - I think Photon is the name - that you can then run flash off of that I believe.
It will. Mine is stock and flash installed and works with Firefox.
Wrong. It will. OP's doing something incorrectly....
// Tapatalk HD for Android - Nexus 7 //
get the file which is in the first post you may of downloaded a dodgy app. Id run a virus scan just incase
I installed xscope pro, which has an option to download flash in its settings. It works fine for me to go to sites requiring flash through xscope.
Gary59t
