Nexus 7: Sleeve with thick BobJ case?
Re: Sleeve with thick BobJ case?
I almost pulled the trigger on a few like Ultra50 posted there....but held off. I kept looking at all the bay listings and amazon listings of neoprene type sleeves that would fit the N7 with the Bobjgear on. You have to get accurate inner dimensions of these to make a good decision on fit. When you see some with pictures of a mini Ipad or a new N7 sticking out of it...you can sort of get an idea of the width or thickness of fit...but not the length which many are pretty tight even without any cause or thin covers on the N7. Then read any reviews of purchasers who seem to make accurate comments on fit.
I was always looking for a simple neoprene sleeve and could easily find tons of these very cheap $1 to $6 ones all made probably at the same factory in China. This Ebay listing showed one with a longer and wider dimension than the normal ones you see fit for 7 inch tabs. It's pictures with a mini Ipad...you can see the extra room from that.
So i got it cheap and very quick. It easily fits the 2013 with a Bobjgear on it. I might modify the opening flap area though. To pull the small end over the remaining part of the tablet sticking out takes too long and both hands. I would like to slit the sides of the top flap open and add a velcro strap to keep it shut. Some simple cutting and sewing could accomplish this easy.
Length is just enough (8.4 inches minimum is needed for sure) and the extra width could be used for few small extra things (like a stylus, otg cable, flash drive, ear pods, or blue tooth headset). The tablet is not going to move around inside as the rubber of the bobj case holds without slippage on the neoprene inside.
Can't tell if you're being sarcastic or not...
A pistol case??? The hell man.
tandolker
