Nexus 7 stuck at lock screen
Pat Murray1
7
My (1st gen) Nexus 7 is stuck at the lock screen. I have soft rebooted it, nothing. Then I wiped the cache. It is still stuck at the lock screen. Any recommendations??
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,930
5,234
113
Welcome to Android Central! So you're unable to do anything on the lockscreen? Does it register any touch? Is it set to slide unlock, or do you need to enter a PIN or pattern?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,930
5,234
113
What do you mean pulldown menus? There are no pulldowns on the lockscreen. I wonder if we're talking about the same thing.
brosko
1,466
I can use the pull down menus but nothing else.
I have seen this before on a samsung tablet, where it wouldn't recognize touch to unlock it from the lock screen but could still pull down the notification shade. I don't have an answer for you unfortunately, but it would be nice to figure this out.
Pat Murray1
7
The "lock" is on the screen. It is my normal start up page after it boots up. I REALLY want to get this fixed. I can't afford a new tablet right now.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,930
5,234
113
When you say you wiped the cache, do you mean wiping the system cache partition from the Recovery Menu?
Pat Murray1
7
I did do a cache reset before but I just did a hard reset. I thought I had it fix BUT when I tried to connect my WiFi it let me type in my password but it would not let me connect it. I am REALLY lost now.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,930
5,234
113
Try rebooting your router by unplugging its power for 10 seconds, then plugging back in.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,930
5,234
113
Still worth trying, since it's simple and quick. Wi-Fi devices can behave oddly when it comes to routers, so this is an easy way to narrow the problem down.
Alyssa Daniels
when i press the unlock button, and it wakes up, i am able to enter in my password, but it doesnt do anything when i press "done" to unlock the nexus. Sometimes it freezes completely, sometimes im able to push the letters on the keybored, they will light up but it doesnt type anything. the last thing i want to do is reset the whole thing, i have way to many items that i cant lose. please help, thank you
dxrrk
