- Aug 19, 2012
- 2
- 0
- 0
I purchased a 2013 Nexus 7, and while about 15 feet away from my router with line of sight, unfortunately I only have one bar of wifi (and the service is spotty at best with constant disconnects). In addition to this, I can't see ANY of the other routers that I can see on my computer, galaxy nexus, pre3, iphone, laptops, or touchpads, including my access point, which I have upstairs.
I've read plenty of threads about people having issues like this after the 4.3 update with the 2012 N7, but after scouring the depths of the net, I can't find anyone with similar issues on the 2013 version (aside from GPS, multitouch, and the static X).
Has anyone else experienced this? If so, did you fix it somehow or return/exchange it? As far as I can tell, I don't have any of the other issues, so I'd like to avoid exchanging if possible so as to avoid getting one of the other lemons.
-LarrySteeze
Edit: For the record, I did the upgrade to 4.4 with no change in wifi reception.
-LarrySteeze
