Nexus 7 will not connect to WIFI
Priscilla Johnson
Active member
Nov 19, 2012
41
My Nexus 7 will not connect to any WIFI. It recognizes the WIFI but will not connect. I tried to get it share data with my phone but that doesn't work either. It does not see the connection for my phone. I've restarted it but that does not help. Any help is appreciated. Thanks,
Are all of these Wi-Fi sources secured, or have you tried any Open sources (Starbucks, McDonald's, etc)?
What is the signal strength like for these sources? Rather than trusting the little bars on the Wi-Fi icon you could use an app like SignalCheck Lite http://market.android.com/details?id=com.blueline.signalchecklite or Wifi Analyzer http://market.android.com/details?id=com.farproc.wifi.analyzer to get a precise measurement.
When you say that it won't connect, what do you mean exactly? Does it attempt to obtain an IP address, fail, and then show 'Saved'?
Have you tried booting into Safe mode? Or a complete power off?
Did it ever work?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
ahmadirsyah
