Question No calls received until reboot - problem
Jeff C3
10
I try to reboot my Samsung Xcover 5 every morning (Android 14). If I forget, I won't receive any phone calls. That's even if I used the phone for something else. Any thoughts?
Are you certain Do Not Disturb isn't being turned on automatically on some schedule?
If you look at the Call History, do you see any Missed Calls? I wonder if the problem is more that the phone isn't notifying you of the calls.
Also, which carrier are you using?
Good question. I should have mentioned that there is no record of any calls during that period, even though people said they had called.
T-Mobile.
I even re-imaged my phone - same result.
opegamani
