no data problem
nate1dawgg
Active member
Oct 27, 2010
31
I'm having a problem with getting any data connectivity. It was doing just fine until this morning. I've installed the newest cm nightly as well as the newest incredikernal to no avail. I installed the Amazon app store this morning but I don't know if that had anything to do with the problem. I'm out of ideas and I'd rather turn to you guys instead of big reds customer service. Any help is appreciated.
*edit. - I've also made sure the network data is checked and its not a factor of poor reception
No Data as well and all apps keep "Forceclosing" + low memory/data.
I'm havignt he same problem here including: Low memory (even after I uninstalled a rack of my apps), low data and no Mobile Data even though i'm connected fine to my wirless network. This sounds like it might be a Verizon issue. :mad:
I was thinking the same thing, however my wife has no problem and she has a DInc as well. I also have talked with one of my co-workers on Verizon and she is having no problems either...:confused:
Alright, so I haven't any idea what happened, but I seem to have 3G data coverage again. I didn't even do anything, but not complaining :)
I've had it every once and a while drop my data and grey out my turn off or on mobile network.
Typically a simple restart of the phone does the trick and the 3g kicks back on. I have no idea what causes it, but it happens pretty rarely.
Reactions: nate1dawgg
Perhaps that's it, because I did do a battery pull before it started working again, so maybe that did solve the problem :-\
