No led....no saving my settings.
Heath276
458
20
I have had no led well forever now well starting last night it has stoped saving my settings like the size and I like it to show the time the message came in. Is anyone else having this problem? I reinstall it 2 times now went to clean it and everything. I do think I had a update for it a few days ago but don't know if that would cause it. I am rooted on 2.2 with 2.8 sc and the midnight steal blue theme.
Sent from my SCH-I500 using Tapatalk
did you wipe data and cache before you flashed 2.8?
Yea it was working now nothing so no clue what's going on.
Yep did that to so no clue guess its just not playing nice with somthing I got owell guess I will live with it for now.
I have a similar problem with Launcher Pro. Everything worked fine until i went to SC 2.8. Now Launcher Pro isn't saving the settings and it goes back to the default settings every time.
Reactions: gunnermike53
OH!!! DUH!!! with root explorer. dbdata/databases/com.fefe.launcher and delete that whole folder. then restart.
Reactions: sparesr4sissies
Yea my lp+ did that to me but I fixed it by just downloading it again the noled wont save it at all if I set it up and turn off my phone as soon as I turn it back on and go in the noled its back to default.
delete that fede folder and tell me what happen. i bet that will work.
Hold on what do I delete? There's no fede for noled there is a com.led notify file in the databases file
Yep no clue what u r talking about sorry im at work too so trying to do this and work at the same time but im lost sorry dude.
Open root explorer. At the very top you will see parent folder. Press that until parent folder goes away. Now you are at the root. Now follow the folder path I posted earlier.
OK but are you talking about launcher pro because it works now but at first it would no save sitting but i just redownloaded it and it works fine so the no led is whats not saving now should i go in and delete the noled file in there and see if that works?
couldnt hurt. you will have to setup launcher pro again, but that only takes a second.
Ok I did that it didn't work but owll im going to flash 2.9 tonight so it may work after that I hope.
robert522002
