No sound from earpiece, sound from speaker
Nigel Huang
21
When I make calls and recieve calls, no sound comes from the earpiece at the top, the volume level is maxed out and nothing. Then when I go and press the speaker it works. The phone is only 1 week old... the only thing installed is battery doctor
Same issue, tried everything possible from downgrading the OS and radio firmware. To trying different ROMs, nothing has helped so far.
Maybe the headphone jack is stuck. You can try an insert a headphone, see if that works, then pull it out again and see if the earpiece works again.
May be worth a try.
nemismom
