No sound on keyboard click
Status
Not open for further replies.
Jecho66
10
Hi,
I already had asked this question as a guest, but as adviced, I had created an account so it was easier to answer questions and reply to things.
Here is my situation.
I am using Android 8.1. All updates are installed.
When I hit a "key" on the keyboard, there is no sound.
When I go through all the settings, I check the settings for sound on the keyboard.
It is set to ON. Just to make sure, I turn it OFF and back ON again.
After that, when I use the keyboard, the sound is there.
But after a restart or turn OFF and ON my tablet, the sound is gone again.
Only when I go to the settings and turn it OFF and ON again, the sound is back again.
It is a bit annoying, to every time turn OFF and turn ON the settings, to have the sound again.
Hope anyone has a permanent solution for this.
I am using the standard keyboard Gboard.
I did not installed any other keyboards.
As I mention, if I look in the settings, it is all ON.
Only by turning it OFF and ON again, after every boot or reboot, then the sound is there.
I am using android version 8.1.0 with kernel version 3.18.71
I have a Lenovo Tab 4 8
I already had contacted Lenovo about this, but they only can help me if it is a hardware problem and so far, it doesn't look like a hardware issue.
Many thanks for the tips and trick.
Hi,
Hi , thanks for registering
If you could follow up in your orginal link , so we dont have 2 threads on same topic thanks
I'll provide the link.
https://forums.androidcentral.com/showthread.php?t=968541
Status
FahadsTech
