- Nov 17, 2012
- 101
- 0
- 0
I've got the v20, which I love. I know I'm eventually going to have to upgrade and that there will be no more option for swapping batteries. Is there an alternative to power charging that everyone is using?
You can do water resistant (no phone is waterproof) with a removable battery. That may be part of it, but I think it's more a demand for paper thin phones and cheaper manufacturing contributing to this trend. If there were more profit in removable batteries, I can promise you all phones would still have them.Blame all the people who want waterproof cellphones for all the manufacturer's need to not have phones with swappable batteries. Life goes on.
Unfortunately, this isn't always convenient. But I don't hardly plug my phone into charge it so yes it charges slowly.You don't want to charge any battery fast. It damages it. Hits it with several amps of current. You want long slow charge overnight.
I need this for an lg v series device when I upgrade to the v30/40 player this year.Samsung S8+ has this ZeroLemon device - they call it a battery but it's more of a powerbank that contains a battery inside a case. You insert the phone into the device and it actually makes it a lot easier to hold. Gives it some depth.
So when your battery runs low, just push the 'on' button and recharge it.
A Li-ion battery can be charged at 1C without any appreciable degradation. 1C is charging at a rate equal to its capacity. So if it's a 3400mAh (3.4Ah) battery, you can charge at 3.4A fine. Some Li-ion battery technologies, like graphine, allow for higher charge rates. As the batteries fill, the phone throttles the charge on their own to finish off the charging.You don't want to charge any battery fast. It damages it. Hits it with several amps of current. You want long slow charge overnight.
What's the difference between adding a mod and popping your phone into a battery case? Same same.For removable batteries I went with the Z2 Force. The battery mods act like a extra battery and they are always on sale. I got an incipio battery for 10 back in November.
The problem with overnight charging is the possibility of holding the battery over 80% charged. High charge states will cause accelerated wear on Li-ion's as well. If you want to charge overnight, I'd do what I saw another member suggest. Use an outlet timer and plug the charger into that, and set the timer to shut power off after a certain length of time. This puts a charge to the phone, but reduces the chance of dwelling at a high charge level.
