Normal battery usage readings?
fwarchol
Active member
Feb 2, 2011
28
Just checking to see if there is something I need to tweak on my phone with these types of readings........or is it normal?
ANDROID SYSTEM - 67%
DISPLAY - 18%
CELL STANDBY - 15%
Thanks again!
Unfortunately there is really no such thing as normal....each peron will have different usage percentages......monitor ur particular usages and then you should be able to figure out whats normal for you......menc-settings applications-running apps will help you to turn off some apps and give you better numbers tho
DISPLAY - 18%
CELL STANDBY - 15%
Thanks again!
I am evaluating the battery drain with Battery Monitor Widget. If I get 70ma in standby mode I am happy. 90ma is still good, 60ma makes me really happy.
MichaelCrusan
