Not all Note 8 features working with Consumer Cellular
freeman10
19
Hello, I purchsed a used Note 8 about a month ago. Factory unlocked - CDMA + GSM. Using with Consumer Cellular, which I had used with my previous Samsung phone (AT&T unlocked) without issue. The person who had the Note 8 before me had used it with Sprint. When I used it, I noticed that I was not getting any voicemail notifications at all, and Visual Voicemail app was not an available feature -- it wasn't even listed as an option. I would receive voicemail messages but would only know that I had them if I actually called into voicemail. The other issue I noticed was that MMS messages would not send/be received with the stock Samsung message app when WiFi was turned on. WOULD send/be received through Google messages.
I went back to where I purchased the phone, and they put in an AT&T SIM (Consumer Cellular uses AT&T or T-Mobile towers). The AT&T background apps, if that's the correct term, installed on the phone. When you start the phone, the AT&T icon now appears instead of the Sprint icon. When we took the AT&T SIM out and switched back to the Consumer Cellular SIM, voicemail notifications then began working, AND a working visual voicemail option was now available. Also, MMS messages started sending/receiving in the Samsung messages app with WiFi on.
I thought all of my issues were resolved until I noticed that I now can't successfully send emojis in the Samsung messages app when sending a SMS, only when sending a MMS. When I send them, the emojis are received as question marks. Before sending a SMS with an emoji, the phone tells me to go to Settings to change the input mode to "automatic." However, when I click on Settings, the ONLY option I am given is to "Manage SIM card settings." There is NO option to change the input mode to "automatic." I can't find it anywhere in the phone.
There also does not seem to be an option to turn on WiFi calling. I honestly don't remember if this was an option or not before we put the AT&T SIM in the phone. Consumer Cellular says that WiFi calling is activated on their end.
Does anyone using Consumer Cellular have any ideas? I am using the AT&T Consumer Cellular SIM. Could using the T-Mobile Consumer Cellular SIM change any of this? Or put an AT&T SIM or T-Mobile SIM into the phone and see if that enables any options to change any settings? Anyone dealt with this before? Thanks!
I thought all of my issues were resolved until I noticed that I now can't successfully send emojis in the Samsung messages app when sending a SMS, only when sending a MMS. When I send them, the emojis are received as question marks. Before sending a SMS with an emoji, the phone tells me to go to Settings to change the input mode to "automatic." However, when I click on Settings, the ONLY option I am given is to "Manage SIM card settings." There is NO option to change the input mode to "automatic." I can't find it anywhere in the phone. This didn't occur prior to inserting the AT&T SIM.
Settings in the SMS app. If there's no "automatic", look for something to not break SMS messages.
WiFi calling is carrier-specific. If it's not an AT&T phone, it probably won't have what AT&T needs for WiFi calling.
Consumer Cellular seems to think that my problems stem from this being a CDMA unlocked phone and that a GSM unlocked phone would work better. Does anyone using Consumer Cellular have any ideas? I am using the AT&T Consumer Cellular SIM. Could using the T-Mobile Consumer Cellular SIM change any of this? Or put an AT&T SIM or T-Mobile SIM into the phone and see if that enables any options to change any settings? Anyone dealt with this before? Thanks!
No, using an AT&T phone with an AT&T SIM would probably solve the problems. Or a TMobile SIM with a TMobile phone.
Thanks for your reply! I have done more research, and some features on factory unlocked phones (video calling, WiFi calling) can apparently be unavailable even when signed up with a carrier that typically enables it, i.e., AT&T?
Regarding the SMS emoji issue in the Samsung stock messaging app, the only setting that I have available in "Text Messages" is "Manage SIM card messages." While I am told to "change the input mode to automatic," the option to do that is not there. There also is no option not to break SMS messages -- only the option to "Manage SIM card messages." When I click on that, it says, "No messages." Sending emojis works fine in MMS.
DanishDanuu
