Not sure if im rooted or not/is it possible for my Galaxy S5 to unroot by itself?
Sep 12, 2014
5
Ok so I rooted my Samsung GS5 4.4.2 (AT&T) with towel root. Everything worked great. So after a month or two, apps that needed root support stopped working and root checker said I wasn't rooted plus a seemingly massive power drain all without me doing anything related to the unroot process... Not only that, the Samsung updater thing will not let me update to Kitkat 4.4.4 or Lollipop 5.0. Any ideas? Am I half rooted or something?
it does sound like you have the remnants of root keeping you from updating through OTA.
download root checker and see what it says although I'm pretty sure you're not rooted if apps are not asking for superuser permission and are not functioning properly
I already have root checker installed and it says 'Sorry! Root access is not properly installed on this device.' Any suggestions on what I should do? Should I just give up and do a factory reset or something?
it's been a long time since I've rooted a samsung galaxy phone the last was the galaxy s2. Id check the root subsection on this form just look up top ⬆ its in the sub forums where you originally posted your thread.
they can probably offer you a better way than FDR.
If it's still on 4.4.2, and the kernel is still dated June 2, 2014 or earlier, just run Towel Root again.
duarty
