Note 2 battery replacement
jlost
Trusted Member
Aug 6, 2010
1,539
147
58
Does anyone know of a replacement battery for the note 2 that is "slim extended" that will fit the OEM case. If not I can just get the OG battery. I think I may need a replacement as my battery is about 1yr 8mths old and it is being used more than it should. I even killed it to the point of the phone having to shut off and charging it back fully. Thanks.
I don't think you'll find a larger battery that will fit the existing case. Let us know how getting a replacement goes.
Will do. It will take a few as I am going to need to order it off Amazon.
It seems that this battery is lasting longer. When I take it off of the charger it doesn't go down to 98% in a minute like the old one did. I'm happy so far.
kimlien
