Note 2 stuck on firmware upgrade encountered an issue screen
djpay10
17
Hey guys
My note 2 ( SGH-I317M) is stuck on the firmware upgrade encountered an issus. please select recovery mode in kies & try again. I hooked it up to kies and tried to fix it but it said "SGH-I317M" does not support initialising. someone please help
thanks
Re: Note 2 stuck on firmware upgrade encountered an issus. screen
Hey guys
thanks
Welcome to Android Central :)
Does this happen when trying to update with an OTA?
Is the phone rooted?
Sent from my Galaxy S4 running SlimKat 4.4.2
phones not rooted just was playing a game phone turned off so I powered it back up and its stuck on this screen
Were you downloading an update?
Sent via Tapatalk
maybe it was doing a auto update not to sure
Can you get into recovery or download mode?
From a Sprint Moto X using AC Forums app
I can get it to download mode
Recovery mode doesn't work?
OK, you can flash the stock firmware, and that should fix it, but all your data like pics/apps and such will be deleted 😩
download mode does nothing i let it do its thing for 4 hrs and nothing. how do i flash the stock firmware?
thank you for your help ill try it when i get home from work and let you know how it goes
No problem. Before you do it, plug the phone into the PC and see if you can retrieve any important data you have stored if it's not already backed up
how do I get a copy of my stock ROM ?
it failed on odin after I put the pda on and hit start only got to the setup connection then said cant open the serial(com) port and it says fail! on the top of odin.... any ideas?
Hmm, OK, but before it failed, it started to flash though, correct?
You can try downloading it again, sometimes there are bad downloads.
failed again said this
<ID:0/004> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> I317MVLUCMK5_I317MOYACMK5_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/004> Odin v.3 engine (ID:4)..
<ID:0/004> File analysis..
<ID:0/004> SetupConnection..
<ID:0/004> Initialzation..
<ID:0/004> Get PIT for mapping..
<ID:0/004>
<ID:0/004> There is no PIT partition.
<OSM> All threads completed. (succeed 0 / failed 1)
<ID:0/004> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/004>
When doing it, you only have PDA selected, right? And F. Reset is off?
Try updating Samsung drivers to your PC, different cables and USB ports.
Skywalkerbc22
