Note 3 and Kit Kat
Bernard Borg
Hi all, I am asking if anyone encountered this or knows how to fix it. Yesterday late afternoon Android Kit Kat for my note 3 was available :) silly me i opted for the upgrade suddenly the phone is very sluggish, un responsive after unlock ( basically I found that if you slide down the notification toolpane it works, you press on setting so the ui starts to get commands.) home button and back slugish take an awful amount of presses to respond ( was my upgrade broken ?)
Help is appreciated :)
Bernard
Try a reboot. Most likely you did that so seeing as how you just installed the new update if this was me I would just do a factory reset.
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
Try a reboot as suggested above. If that doesn't fix your issue completely consider a factory reset, which should help clear out that problem.
MidnightRaven9
