Note 3 Battery Info - Incorrect
PierreChacko
12
Hi,
I have got my Samsung Note 3 battery charged fully, however, when i go to settings > General > Battery, it shows me 30 sec on battery which according to me seems to be weird. The battery however performs well, its just that the info seems to be incorrect. I've tried to restart, shutdown, remove the battery & put it back in, it's all the same.
Any expert advice? Let me know.
Thanks
Pierre
Hi,
hmm, sound a great problem i think you should visit the nearest samsung support because the problem looks to be in the technical end !!
Thanks
Pierre
Hi,
Thanks
Pierre
Welcome to Android Central :)
When you fully charge the battery, it will reset the amount of time on the battery. Same will happen if you reboot at any percentage over 90% (Not sure why they do this)
